Arigatoni: Overlaying Internet via Low Level Network Protocols - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We design a lightweight communication model, called Arigatoni, with related architecture, that is suitable to deploy the Global Computing Paradig} over the Internet. Communication over the behavioral units of the model are performed by a simple communication protocol on top of TCP or UDP protocol. Basic global computers can communicate by first registering to a brokering service and then by mutually asking and offering services, in a way that is reminiscent to Rapoport's tit-for-tat strategy of co-operation based on reciprocity. In the model, resources are encapsulated in the intranet in which they reside, and requests for resources located in another intranet traverse a broker-2-broker negotiation using classical PKI mechanisms. The model is suitable to fit with various global scenarios from classical PtP application, like file sharing, or band-sharing, to more sophisticated GRID application, like remote and distributed big (and small) computations, until possible, futuristic real migration computations, in the vein of the programming language Obliq by Luca Cardelli.
RR-5805.pdf (303.63 Ko) Télécharger le fichier
inria-00070219 , version 1 (19-05-2006)
  • HAL Id : inria-00070219 , version 1
Didier Benza, Michel Cosnard, Luigi Liquori, Marc Vesin. Arigatoni: Overlaying Internet via Low Level Network Protocols. [Research Report] RR-5805, INRIA Sophia Antipolis - Méditerranée; INRIA. 2006, pp.27. ⟨inria-00070219⟩
363 Consultations
258 Téléchargements
