Understanding Collateral Evolution in Linux Device Drivers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
In a modern operating system (OS), device drivers can make up over 70% of the source code. Driver code is also heavily dependent on the rest of the OS, for functions and data structure defined in the kernel and driver support libraries. These two properties together pose a significant problem for OS evolution, as any changes in the interfaces exported by the kernel and driver support libraries can trigger a large number of adjustments in dependent drivers. These adjustments, which we refer to as collateral evolutions, may be complex, entailing substantial code reorganizations. Collateral evolution of device drivers is thus time consuming and error prone. In this paper, we present a qualitative and quantitative assessment of the collateral evolution problem in Linux device driver code. We provide a taxonomy of evolutions and collateral evolutions, and show that from one version of Linux to the next, collateral evolutions can account for up to 35% of the lines modified in such code. We then identify some of the challenges that must be met in the future to automate the collateral evolution process.
RR-5769.pdf (416.85 Ko) Télécharger le fichier
inria-00070251 , version 1 (19-05-2006)
  • HAL Id : inria-00070251 , version 1
Yoann Padioleau, Julia L. Lawall, Gilles Muller. Understanding Collateral Evolution in Linux Device Drivers. [Research Report] RR-5769, INRIA. 2005, pp.18. ⟨inria-00070251⟩
199 Consultations
465 Téléchargements
