Improper colouring of (random) unit disk graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
For any graph $G$, the $k$-improper chromatic number $\chi^k(G)$ is the smallest number of colours used in a colouring of $G$ such that each colour class induces a subgraph of maximum degree $k$. We investigate the ratio of the $k$-improper chromatic number to the clique number for unit disk graphs and random unit disk graphs to generalise results where only proper colouring was considered.
RR-5761.pdf (217.93 Ko) Télécharger le fichier
inria-00070259 , version 1 (19-05-2006)
  • HAL Id : inria-00070259 , version 1
Ross J. Kang, Tobias Müller, Jean-Sébastien Sereni. Improper colouring of (random) unit disk graphs. [Research Report] RR-5761, INRIA. 2005, pp.18. ⟨inria-00070259⟩
124 Consultations
183 Téléchargements
