An Advanced Configuration and Duplicate Address Detection mechanism for a multi-interface OLSR Network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Cédric Adjih
Philippe Jacquet
Anis Laouiti
Paul Mühlethaler
  • Fonction : Auteur
  • PersonId : 833453
Mobile Ad hoc NETworks (MANETs) are infrastructure-free, highly dynamic wireless networks, where central administration or configuration by the user is very difficult. In hardwired networks nodes usually rely on a centralized server and use a dynamic host configuration protocol, like DHCP, to acquire an IP address. Such a solution cannot be deployed in MANETs due to the unavailability of any centralized DHCP server. For small scale MANETs, it may be possible to allocate free IP addresses manually. However, the procedure becomes impractical for a large-scale or open system where mobile nodes are free to join and leave. Numerous dynamic addressing schemes for ad hoc networks have been proposed. These approaches differ in a wide range of aspects, such as the usage of centralized servers or full decentralization, hierarchical structure or flat network organization, and explicit or implicit duplicate address detection. In this paper we will present a complete and optimized version of the auto-configuration solutions for OLSR , that we have already proposed in and . This solution works in the case of a nodes having multiple interfaces, and is based on an efficient Duplicate Address Detection(DAD) algorithm which takes advantage of the genuine optimization of the OLSR routing protocol. A proof of the correct operation of the proposed solution is given and the communication overhead induced is evaluated.
Autre [cs.OH]
RR-5747.pdf (860.53 Ko) Télécharger le fichier
inria-00070272 , version 1 (19-05-2006)
  • HAL Id : inria-00070272 , version 1
Cédric Adjih, Saadi Boudjit, Philippe Jacquet, Anis Laouiti, Paul Mühlethaler. An Advanced Configuration and Duplicate Address Detection mechanism for a multi-interface OLSR Network. [Research Report] RR-5747, INRIA. 2005, pp.31. ⟨inria-00070272⟩
312 Consultations
81 Téléchargements
