Ghost Process: a Sound Basis to Implement Process Duplication, Migration and Checkpoint-Restart in Linux Clusters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Process management mechanisms (process duplication, migration and checkpoint-restart) are very useful for high performance and high availability in clustering systems. The single system image approach aims at providing a global process management service with mechanisms for process checkpoint, process migration and process duplication. In this context, a common mechanism for process virtualization is highly desirable but traditional operating systems do not provide such a mechanism. This paper presents a kernel service for process virtualization called ghost process, extending the Linux kernel. The ghost process mechanism has been implemented in the Kerrighed single system image based on Linux.
RR-5735.pdf (336.7 Ko) Télécharger le fichier
inria-00070283 , version 1 (19-05-2006)
  • HAL Id : inria-00070283 , version 1
Geoffroy Vallée, Renaud Lottiaux, David Margery, Christine Morin, Jean-Yves Berthou. Ghost Process: a Sound Basis to Implement Process Duplication, Migration and Checkpoint-Restart in Linux Clusters. [Research Report] RR-5735, INRIA. 2005, pp.16. ⟨inria-00070283⟩
173 Consultations
135 Téléchargements
