An explicit formulation of the multiplicative Schwarz preconditionner - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We provide an explicit formulation of the splitting associated with the Multiplicative Schwarz iteration. We show the advantage of considering the explicit formulation, when the iteration is used as a preconditioner of a Krylov method.
RR-5685.pdf (352.83 Ko) Télécharger le fichier
inria-00070328 , version 1 (19-05-2006)
  • HAL Id : inria-00070328 , version 1
Guy Antoine Atenekeng Kahou, Emmanuel Kamgnia, Bernard Philippe. An explicit formulation of the multiplicative Schwarz preconditionner. [Research Report] RR-5685, INRIA. 2005, pp.25. ⟨inria-00070328⟩
160 Consultations
540 Téléchargements
