Design of Robust Receding Horizon Controls for Constrained Polytopic-Uncertain Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
In this paper, we propose a new robust receding horizon control scheme for linear input-constrained discrete-time systems with polytopic uncertainty. We provide a rigorous proof for closed-loop stability. The control scheme is based on the minimization of the worst-case cost with time-varying terminal weighting matrices, which can easily be implemented by using linear matrix inequality optimization. We discuss modifications of the proposed scheme that improves feasibility or on-line computation time. We compare the proposed schemes with existing results through simulation examples.
Autre [cs.OH]
RR-5647.pdf (156.42 Ko) Télécharger le fichier
inria-00070362 , version 1 (19-05-2006)
  • HAL Id : inria-00070362 , version 1
Ki Baek Kim. Design of Robust Receding Horizon Controls for Constrained Polytopic-Uncertain Systems. [Research Report] RR-5647, INRIA. 2005, pp.16. ⟨inria-00070362⟩
97 Consultations
89 Téléchargements
