An algorithm for reporting maximal c-cliques - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Frédéric Cazals
Given two graphs, a fundamental task faced by matching algorithms consists of computing either the (Connected) Maximal Common Induced Subgraphs ((C)MCIS) or the (Connected) Maximal Common Edge Subgraphs ((C)MCES). In particular, computing the CMCIS or CMCES reduces to reporting so-called connected cliques in product graphs, a problem for which an algorithm has been presented in a recent paper I. Koch, TCS 250 (1-2), 2001. This algorithm suffers from two problems which are corrected in this note.
Autre [cs.OH]
RR-5642.pdf (116.29 Ko) Télécharger le fichier
inria-00070365 , version 1 (19-05-2006)
  • HAL Id : inria-00070365 , version 1
Frédéric Cazals, Chinmay Karande. An algorithm for reporting maximal c-cliques. [Research Report] RR-5642, INRIA. 2006, pp.10. ⟨inria-00070365⟩
71 Consultations
236 Téléchargements
