s'authentifier
version française rss feed
inria-00070382, version 1
Meshing Volumes Bounded by Smooth Surfaces
Steve Oudot 1, Laurent Rineau 12, Mariette Yvinec () 1
N° RR-5626 (2006)
Résumé : This paper introduces a three-dimensional mesh generation algorithm for domains bounded by smooth surfaces. The method combines a surface mesher with a volume mesher, both based on Delaunay refinement, to get a greedy algorithm that samples the interior and the boundary of the domain at once. The algorithm constructs provably-good meshes, it gives control on the size of the mesh elements through a user-defined sizing field, and it guarantees the accuracy of the approximation of the domain boundary. A noticeable feature is that the domain boundary has to be known only through an oracle that can tell whether a given point lies inside the object and whether a given line segment intersects the boundary. This makes the algorithm generic enough to be applied to a wide variety of objects, ranging from domains defined by implicit surfaces to domains defined by level-sets in 3D grey-scaled images or by point-set surfaces.
  • Domaine : Informatique/Autre
  • Mots-clés : MESH GENERATION – RECONSTRUCTION – SAMPLING – DELAUNAY REFINEMENT
  • Référence interne : RR-5626
  • inria-00070382, version 1
  • oai:hal.inria.fr:inria-00070382
  • Contributeur :
  • Soumis le : Vendredi 19 Mai 2006, 20:19:32
  • Dernière modification le : Mardi 30 Janvier 2007, 16:11:32
tous les articles de la base du CCSd...
