Error estimates for a stochastic impulse control problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We obtain error bounds for monotone approximation schemes of a stochastic impulse control problem. This is an extension of the theory for error estimates for the Hamilton-Jacobi-Bellman equation. For obtaining these bounds we build a sequence of stochastic impulse control problems, and a sequence of monotone approximation schemes. Extending methods of Barles and Jakobsen , we give error estimate for each problem of the sequence. Using these bounds we obtain the result. We obtain the same estimate on the rate of convergence as in the equation without impulsions .
RR-5606.pdf (356.42 Ko) Télécharger le fichier
inria-00070401 , version 1 (19-05-2006)
  • HAL Id : inria-00070401 , version 1
J. Frederic Bonnans, Stefania Maroso, Hasnaa Zidani. Error estimates for a stochastic impulse control problem. [Research Report] RR-5606, INRIA. 2005, pp.31. ⟨inria-00070401⟩
139 Consultations
88 Téléchargements
