Active SVM-based Relevance Feedback with Hybrid Visual and representation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Most of the available image databases have keyword annotations associated with the images, related to the image context or to the semantic interpretation of image content. Keywords and visual features provide complementary information, so using these sources of information together is an advantage in many applications. We address here the challenge of semantic gap reduction, through an active SVM-based relevance feedback method, jointly with a hybrid visual and conceptual content representation and retrieval. We first introduce a new feature vector, based on the keyword annotations available for the images, which makes use of conceptual information extracted from an external ontology and represented by ``core concepts''. We then present two improvements of the SVM-based relevance feedback mechanism: a new active learning selection criterion and the use of specific kernel functions that reduce the sensitivity of the SVM to scale. We evaluate the use of the proposed hybrid feature vector composed of keyword representations and the low level visual features in our SVM-based relevance feedback setting. Experiments show that the use of the keyword-based feature vectors provides a significant improvement in the quality of the results.
RR-5558.pdf (537.42 Ko) Télécharger le fichier
inria-00070448 , version 1 (19-05-2006)
  • HAL Id : inria-00070448 , version 1
Marin Ferecatu, Michel Crucianu, Nozha Boujemaa. Active SVM-based Relevance Feedback with Hybrid Visual and representation. [Research Report] RR-5558, INRIA. 2005, pp.20. ⟨inria-00070448⟩
98 Consultations
142 Téléchargements
