Feedback control for competition models with different removal rates in the chemostat - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
We consider the feedback control for a model of competition in a chemostat with one single substrate and two species. De Leenheer and Smith [J.Math.Biol.,46 (2003), pp.48-70] studied the competition in the chemostat in the framework of feedback control theory, giving sufficient conditions for the convergence of the species toward a unique stable critical point, thus avoiding the competitive exclusion. Nevertheless, they suppose that the mortality rates can be neglected. In this paper we allow non-zero mortality rates and the results stated before can be extended: We also obtain sufficient conditions (summarized as upper bounds for the size of mortality rates) for the convergence of competing species toward a unique stable critical point.
RR-5555.pdf (462.97 Ko) Télécharger le fichier
inria-00070451 , version 1 (19-05-2006)
  • HAL Id : inria-00070451 , version 1
Jean-Luc Gouzé, Gonzalo Robledo. Feedback control for competition models with different removal rates in the chemostat. [Research Report] RR-5555, INRIA. 2006, pp.26. ⟨inria-00070451⟩
80 Consultations
132 Téléchargements
