A Randomized Quasi-Monte Carlo Simulation Method for Markov Chains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Christian Lécot
  • Fonction : Auteur
  • PersonId : 833463
Bruno Tuffin
  • Fonction : Auteur
  • PersonId : 830166
We introduce and study a randomized quasi-Monte Carlo method for estimating the state distribution at each step of a Markov chain, under the assumption that the chain has a totally ordered (discrete or continuous) state space. The number of steps in the chain can be random and unbounded. The method simulates $n$ copies of the chain in parallel, using a $(d+1)$-dimensional low-discrepancy point set of cardinality $n$, randomized independently at each step, where $d$ is the number of uniform random numbers required at each transition of the Markov chain. This technique is effective in particular to obtain a low-variance unbiased estimator of the expected total cost up to some random stopping time, when state-dependent costs are paid at each step. We provide numerical illustrations where the variance reduction with respect to standard Monte Carlo is substantial. The variance is reduced by factors of several thousands in some cases. We prove bounds on the convergence rate of the worst-case error and variance for special situations. In line with what is typically observed in RQMC contexts, our empirical results indicate much better convergence than what these bounds guarantee.
Autre [cs.OH]
RR-5545.pdf (368.82 Ko) Télécharger le fichier
inria-00070462 , version 1 (19-05-2006)
  • HAL Id : inria-00070462 , version 1
P. L'Ecuyer, Christian Lécot, Bruno Tuffin. A Randomized Quasi-Monte Carlo Simulation Method for Markov Chains. [Research Report] RR-5545, INRIA. 2005, pp.32. ⟨inria-00070462⟩
385 Consultations
1023 Téléchargements
