OSCAR on Debian: the EDF Experience - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Jean-Yves Berthou
  • Fonction : Auteur
EDF
Hugues Prisker
  • Fonction : Auteur
EDF
Daniel Leprince
  • Fonction : Auteur
EDF
Linux clusters are now an interesting solution to execute numerical simulations. But cluster use implies problems of deployment, because of their distributed architecture. In the past, each company developed his own solution based on various tools. Today, software suites like OSCAR are available and can be freely used. But such solutions may not be adapted to the current computing architecture of companies. For example, the current solution deployed inside a company may be based on a Linux distribution not supported by a software suite like OSCAR. Nevertheless, the use of a software suite like OSCAR is very interesting for companies that are not specialized in cluster management. This paper presents the OSCAR port to the Debian distribution in the context of the numerical simulation platform deployed at Électricité de France (Electricity of France).
Autre [cs.OH]
RR-5537.pdf (425.28 Ko) Télécharger le fichier
inria-00070469 , version 1 (19-05-2006)
  • HAL Id : inria-00070469 , version 1
Geoffroy Vallée, Jean-Yves Berthou, Hugues Prisker, Daniel Leprince. OSCAR on Debian: the EDF Experience. [Research Report] RR-5537, INRIA. 2005, pp.13. ⟨inria-00070469⟩
138 Consultations
300 Téléchargements
