Goal-oriented test data generation for programs with pointer variables - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Arnaud Gotlieb
  • Fonction : Auteur
  • PersonId : 830099
Tristan Denmat
  • Fonction : Auteur
  • PersonId : 830865
Bernard Botella
  • Fonction : Auteur
  • PersonId : 833465
Automatic test data generation leads to identify input values on which a selected path or a selected branch is executed within a program (path-oriented vs goal-oriented methods). In both cases, several approaches based on constraint solving exist, but in the presence of pointer variables only path-oriented methods have been proposed. This paper extends an existing goal-oriented test data generation technique to deal with multi-level pointer variables. These pointers are responsible for the existence of difficult conditional aliasing problems that usually provoke the failure of the test data generation process. The key point of our approach is the definition of a new static single assignment form based on the results of an intraprocedural flow-sensitive points-to analysis. This form allows us to propose an overall approach for generating goal-oriented test data in the presence of pointer variables based on the Constraint Logic Programming framework. The approach has been implemented and tested over a few examples extracted from the literature.
RR-5528.pdf (224.2 Ko) Télécharger le fichier
inria-00070479 , version 1 (19-05-2006)
  • HAL Id : inria-00070479 , version 1
Arnaud Gotlieb, Tristan Denmat, Bernard Botella. Goal-oriented test data generation for programs with pointer variables. [Research Report] RR-5528, INRIA. 2005, pp.21. ⟨inria-00070479⟩
119 Consultations
280 Téléchargements
