Small FPGA polynomial approximations with $3$-bit coefficients and low-precision estimations of the powers of x - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
Arnaud Tisserand
Nicolas Veyrat-Charvillon
  • Fonction : Auteur
This paper presents small FPGA implementations of low precision polynomial approximations of functions without multipliers. Our method uses degree-$2$ or degree-$3$ polynomial approximations with at most $3$-bit coefficients and low precision estimations of the powers of $x$. Here, we denote by $3$-bit coefficients values with at most $3$ non-zero and possibly non-contiguous signed bits (e.g. $1.001000\overline1$). This leads to very small operators by replacing the costly multipliers by a small number of additions. Our method provides approximations with very low average error and is suitable for signal processing applications.
RR-5503.pdf (222.46 Ko) Télécharger le fichier
RR2005-08.pdf (802.67 Ko) Télécharger le fichier
inria-00070504 , version 1 (19-05-2006)
  • HAL Id : inria-00070504 , version 1
Romain Michard, Arnaud Tisserand, Nicolas Veyrat-Charvillon. Small FPGA polynomial approximations with $3$-bit coefficients and low-precision estimations of the powers of x. [Research Report] RR-5503, LIP RR-2005-8, INRIA, LIP. 2005, pp.13. ⟨inria-00070504⟩
104 Consultations
218 Téléchargements
