Efficient application-level multicast on a network-aware self-organizing overlay - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
The growth of peer-to-peer applications on the Internet motivates interest in general purpose overlay networks. The construction of overlays connecting a large population of transient nodes poses several challenges. First, connections in the overlay should reflect the underlying network topology, in order to avoid overloading the network and to allow good application performance. Second, connectivity among active nodes of the overlay should be maintained, even in the presence of high failure rates or when a large proportion of nodes is not active. Finally, the cost of using the overlay should be spread evenly among peer nodes for fairness reasons as well as for the sake of application performance. To preserve scalability, we seek solutions to these issues that can be implemented in a fully decentralized manner and rely only on local knowledge from each node. In this paper, we propose an algorithm called the Localiser.
RR-5502.pdf (717.06 Ko) Télécharger le fichier
inria-00070505 , version 1 (19-05-2006)
  • HAL Id : inria-00070505 , version 1
Laurent Massoulié, Anne-Marie Kermarrec, Ayalvadi J. Ganesh. Efficient application-level multicast on a network-aware self-organizing overlay. [Research Report] RR-5502, INRIA. 2005, pp.20. ⟨inria-00070505⟩
118 Consultations
68 Téléchargements
