Clarke Generalized Jacobian of the Projection onto the Cone of Positive Semidefinite Matrices
This paper studies the differentiability properties of the projection onto the cone of positive semidefinite matrices. In particular, the expression of the Clarke generalized Jacobian of the projection at any symmetric matrix is given.
