Interactive out-of-core visualisation of 4-D+t plasma data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
This research report presents a new interactive visualisation technique for exploring plasma behaviors resulting from 4-D+t numerical simulations on regular grids. Therefore, a new out-of-core 4-D+t scalar field visualisation technique, based on a « focus and context » approach is presented. The latter uses a hybrid data compression method. The originality of this work precisely consists in coupling the 3-D visualization with the progressive load and decompression of data in such a way that it still guarantees real-time framerates even on low-end PCs while maintaining a high degree of numerical precision.
Autre [cs.OH]
RR-5444.pdf (1.05 Mo) Télécharger le fichier
inria-00070563 , version 1 (19-05-2006)
  • HAL Id : inria-00070563 , version 1
Christophe Mion, Florence Zara, Jean-Michel Dischler. Interactive out-of-core visualisation of 4-D+t plasma data. [Research Report] RR-5444, INRIA. 2004, pp.28. ⟨inria-00070563⟩
120 Consultations
111 Téléchargements
