A Unifying Local Convergence Result for Newton's Method in Riemannian Manifolds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
We consider the problem of finding a singularity of a vector field $X$ on a complete Riemannian manifold. In this regard we prove a unified result for local convergence of Newton's method. Inspired by previous work of Zabrejko and Nguen on Kantorovich's majorant method, our approach relies on the introduction of an abstract one-dimensional Newton's method obtained using an adequate Lipschitz-type radial function of the covariant derivative of $X$. The main theorem gives in particular a synthetic view of several famous results, namely the Kantorovich, Smale and Nesterov-Nemirovskii theorems. Concerning real-analytic vector fields an application of the central result leads to improvements of some recent developments in this area.
Autre [cs.OH]
RR-5381.pdf (288.92 Ko) Télécharger le fichier
inria-00070622 , version 1 (19-05-2006)
  • HAL Id : inria-00070622 , version 1
Felipe Alvarez, Jérôme Bolte, Julien Munier. A Unifying Local Convergence Result for Newton's Method in Riemannian Manifolds. [Research Report] RR-5381, INRIA. 2004, pp.27. ⟨inria-00070622⟩
90 Consultations
437 Téléchargements
