New Light on Arc Consistency over Continuous Domains - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Gilles Trombettoni
Bertrand Neveu
  • Fonction : Auteur
Hyvönen and Faltings observed that propagation algorithms with continuous variables are computationally extremely inefficient when unions of intervals are used to precisely store refinements of domains. These algorithms were designed in the hope of obtaining the interesting property of arc consistency, that guarantees every value in domains to be consistent w.r.t. every constraint. In the first part of this report, we show that a pure backtrack-free filtering algorithm enforcing arc consistency will never exist. But surprisingly, we show that it is easy to obtain a property stronger than arc consistency with a few steps of bisection. We define this so-called box-set consistency and detail a generic method to enforce it. In the second part, a concrete algorithm, derived from the lazy version of the generic method is proposed. Correctness is proved and the properties are studied precisely.
Autre [cs.OH]
RR-5365.pdf (368.16 Ko) Télécharger le fichier
inria-00070638 , version 1 (19-05-2006)
  • HAL Id : inria-00070638 , version 1
Gilles Chabert, Gilles Trombettoni, Bertrand Neveu. New Light on Arc Consistency over Continuous Domains. RR-5365, INRIA. 2004, pp.26. ⟨inria-00070638⟩
109 Consultations
115 Téléchargements
