Arc-chromatic number of digraphs in which each vertex has bounded outdegree or bounded indegree - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
A $k$-digraph is a digraph in which every vertex has outdegree at most $k$. A $(k\veel)$-digraph is a digraph in which a vertex has either outdegree at most $k$ or indegree at most $l$. Motivated by function theory, we study the maximum value $\Phi(k)$ (resp. $\Phi^\vee(k,l)$ of the arc-chromatic number over the $k$-digraphs (resp. $(k\veel)$-digraphs). El-Sahili showed that $\Phi^{\vee}(k,k)\leq 2k+1$. After giving a simple proof of this result, we show some better bounds. We show $\max\{\log(2k+3), \theta(k+1)\}\leq \Phi(k)\leq \theta(2k)$ and $\max\{\log(2k+2l+4), \theta(k+1), \theta(l+1)\}\leq \Phi^{\vee}(k,l)\leq \theta(2k+2l)$ where $\theta$ is the function defined by $\theta(k)=\min\{s : {s\choose \left\lceil \frac{s}{2}\right\rceil}\geq k\}$. We then study in more details properties of $\Phi$ and $\Phi^{\vee}$. Finally, we give the exact values of $\Phi(k)$ and $\Phi^{\vee}(k,l)$ for $l\leq k\leq 3$.
Autre [cs.OH]
RR-5364.pdf (297.59 Ko) Télécharger le fichier
inria-00070639 , version 1 (19-05-2006)
  • HAL Id : inria-00070639 , version 1
Stéphane Bessy, Etienne E. Birmelé, Frédéric Havet. Arc-chromatic number of digraphs in which each vertex has bounded outdegree or bounded indegree. [Research Report] RR-5364, INRIA. 2004, pp.20. ⟨inria-00070639⟩
97 Consultations
139 Téléchargements
