A Dynamic Preconditioner for Newton-Krylov Algorithms: Application to Fluid-Structure Interaction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Simone Deparis
  • Fonction : Auteur
Xavier Vasseur
  • Fonction : Auteur
We consider linear and nonlinear convergence acceleration techniques in the framework of Newton or inexact Newton methods. The proposed procedure is based on a new dynamic preconditioner to be used in combination with the GMRES method for reducing the cost of solving a sequence of linear systems. A nonlinear convergence acceleration technique based on a previous work by Washio et al. is also added. The benefits of this combination of acceleration techniques is shown on fluid-structure interaction problems in haemodynamics for two- and three-dimensional applications.
Autre [cs.OH]
RR-5352.pdf (414.81 Ko) Télécharger le fichier
inria-00070650 , version 1 (19-05-2006)
  • HAL Id : inria-00070650 , version 1
Simone Deparis, Jean-Frédéric Gerbeau, Xavier Vasseur. A Dynamic Preconditioner for Newton-Krylov Algorithms: Application to Fluid-Structure Interaction. [Research Report] RR-5352, INRIA. 2004, pp.25. ⟨inria-00070650⟩
98 Consultations
241 Téléchargements
