A Convex-Analysis Perspective on Disjunctive Cuts - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
We treat the general problem of cutting planes with tools from convex analysis. We emphasize the case of disjunctive polyhedra and the generation of facets. We conclude with some considerations on the design of disjunctive cut generators.
RR-5317.pdf (312.11 Ko) Télécharger le fichier
inria-00070683 , version 1 (19-05-2006)
  • HAL Id : inria-00070683 , version 1
Gérard Cornuéjols, Claude Lemaréchal. A Convex-Analysis Perspective on Disjunctive Cuts. [Research Report] RR-5317, INRIA. 2004, pp.17. ⟨inria-00070683⟩
69 Consultations
204 Téléchargements
