Incompressible Turbulent Flow Reconstruction by the POD technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
With this work, we intend to achieve reduced dynamical models for an incompressible turbulent external flow. The model is constructed from a set of particle image velocimetry (PIV) measurements, using the velocity field data obtained in previous experiments. The Proper Orthogonal Decomposition (POD) is as a technique which allows the extraction of the significant modes of a flow. It permits to identify modes without any a priori hypothesis, and these are ordered by their associated level of energy. The POD modes are used to formulate a dynamical system which only contains the main features of the flow, a low order dynamical system(LODS). This is achieved by means of a Galerkin projection of the Navier-Stokes Equations with the goal to obtain a system of ordinary differential equations describing the main aspects of the flow without demanding excessive computational requirements.
Autre [cs.OH]
RR-5278.pdf (2.61 Mo) Télécharger le fichier
inria-00070722 , version 1 (19-05-2006)
  • HAL Id : inria-00070722 , version 1
Juan d'Adamo, Guillermo Artana, Jean-Antoine Desideri. Incompressible Turbulent Flow Reconstruction by the POD technique. [Research Report] RR-5278, INRIA. 2004, pp.21. ⟨inria-00070722⟩
181 Consultations
686 Téléchargements
