Uniqueness for a Scalar Conservation Law with Discontinuous Flux via Adapted Entropies - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
We prove uniqueness of solutions to scalar conservation laws with space discontinuous fluxes. To do so, we introduce a partial adaptation of Kruzkov's entropies which naturally takes into account the space dependency of the flux. The advantage of this approach is that the proof turns out to be a simple variant of Kruzkov's original method. Especially, we do not need traces, interface condition, Bounded Variation assumptions (neither on the solution nor on the flux), or convex fluxes. However we use a special 'local uniform invertibility' structure of the flux which applies to cases where different interface condiftions are known to yield different solutions.
Autre [cs.OH]
RR-5261.pdf (237.67 Ko) Télécharger le fichier
inria-00070737 , version 1 (19-05-2006)
  • HAL Id : inria-00070737 , version 1
Emmanuel Audusse, Benoît Perthame. Uniqueness for a Scalar Conservation Law with Discontinuous Flux via Adapted Entropies. [Research Report] RR-5261, INRIA. 2004, pp.19. ⟨inria-00070737⟩
222 Consultations
742 Téléchargements
