A 2d Well-balanced Positivity Preserving Second Order Scheme for Shallow Water Flows on Unstructured Meshes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
We consider the solution of the Saint-Venant equations with topographic source terms on 2D unstructured meshes by a finite volume approach. We first present a stable and positivity preserving homogeneous solver issued from a kinetic representation of this hyperbolic conservation laws system. This water depth positivity property is important when dealing with wet-dry interfaces. Then we introduce a local hydrostatic reconstruction that preserves the positivity properties of the homogeneous solver and leads to a well-balanced scheme satisfying the steady state condition of still water. Finally a second order extension based on limited reconstructed values on both sides of each interface and on an enriched interpretation of the source terms satisfies the same properties and gives a noticeable accuracy improvement. Numerical examples on academic and real problems are presented.
RR-5260.pdf (3.42 Mo) Télécharger le fichier
inria-00070738 , version 1 (19-05-2006)
  • HAL Id : inria-00070738 , version 1
Emmanuel Audusse, Marie-Odile Bristeau. A 2d Well-balanced Positivity Preserving Second Order Scheme for Shallow Water Flows on Unstructured Meshes. [Research Report] RR-5260, INRIA. 2004, pp.31. ⟨inria-00070738⟩
296 Consultations
550 Téléchargements
