Stability Properties of data flows on a CDMA network in macrodiversity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Charles Bordenave
In this report, we analyze a general model of large CDMA networks (Code Division Multiple Access) and we propose a new formalism to represent the workload in wireless networks. We focus on stability issues on the downlink when users in the network want to receive some data from the base stations. We derive the stability region of this data flows system when the network is either in full macrodiversity, in soft handover or in a cellular architecture. In particular, we prove, for the model we consider, that well-designed cellular networks achieve the same stability region as networks in macrodiversity. We extend also our results to networks when slow-fading and mobility are taken into account.
Autre [cs.OH]
RR-5257.pdf (351.67 Ko) Télécharger le fichier
inria-00070741 , version 1 (19-05-2006)
  • HAL Id : inria-00070741 , version 1
Charles Bordenave. Stability Properties of data flows on a CDMA network in macrodiversity. [Research Report] RR-5257, INRIA. 2004, pp.26. ⟨inria-00070741⟩
73 Consultations
79 Téléchargements
