s'authentifier
version française rss feed
inria-00070779, version 1
Over-constrained Weierstrass iteration and the nearest consistent system
Olivier Ruatta () 1, Mark Sciabica, Agnes Szanto
N° RR-5215 (2004)
Résumé : We propose a generalization of the Weierstrass iteration for over-constrained systems of equations and we prove that the proposed method allows us to find the nearest system which has at least $k$ common roots and which is obtained via a perturbation of prescribed structure. In the univariate case we show the connection of ourmethod to the optimization problem formulated by Karmarkar and Lakshmanfor the nearest GCD. In the multivariate case we generalize the expressions of Karmarkar and Lakshman, and give a simple iterative method to compute the optimum. The arithmetic complexity of the iteration is detailed.
  • Domaine : Informatique/Autre
  • Mots-clés : OVER-CONSTRAINED ALGEBRAIC SYSTEMS SOLVING / APPROXIMATED GCD / OVER-CONSTRAINED WEIERSTRASS METHOD
  • Référence interne : RR-5215
  • inria-00070779, version 1
  • oai:hal.inria.fr:inria-00070779
  • Contributeur :
  • Soumis le : Vendredi 19 Mai 2006, 21:36:28
  • Dernière modification le : Mercredi 31 Mai 2006, 14:24:25
tous les articles de la base du CCSd...
