Asymptotic Models for Scattering from Strongly Absorbing Obstacles: the Scalar Case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
We derive different classes of generalized impedance boundary conditions for the scattering problem from highly absorbing obstacles. Compared to existing works, our construction is based on an asymptotic development of the solution with respect to the medium absorption. Error estimates are obtained to mathematically validate the accuracy order of each condition.
Autre [cs.OH]
RR-5199.pdf (705.18 Ko) Télécharger le fichier
inria-00070793 , version 1 (19-05-2006)
  • HAL Id : inria-00070793 , version 1
Houssem Haddar, Patrick Joly, Hoai Minh Nguyen. Asymptotic Models for Scattering from Strongly Absorbing Obstacles: the Scalar Case. [Research Report] RR-5199, INRIA. 2004, pp.42. ⟨inria-00070793⟩
153 Consultations
96 Téléchargements
