EEDA : A New Robust Estimation of Distribution Algorithms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
In this report we address a subtle but important limitation found in the literature for Estimation of Distribution Algorithms (EDAs): symmetric initializations of the EDAs around the optimal solution. We focus our study on the performance of certain EDAs (EMNA-global and PBIL-C) that are asymmetrically initialized far from the optimum. We show and explain the failure of these EDAs under these conditions. These observations lead us to develop a new EDA based on an eigenspace analysis, which we denote by EEDA (Eigenspace EDA). We conclude by analyzing this new EDA and by showing its strengths when compared with EMNA-global and PBIL-C when the optimal solution is unknown.
Autre [cs.OH]
RR-5190.pdf (258.14 Ko) Télécharger le fichier
inria-00070802 , version 1 (19-05-2006)
  • HAL Id : inria-00070802 , version 1
Michael Wagner, Anne Auger, Marc Schoenauer. EEDA : A New Robust Estimation of Distribution Algorithms. [Research Report] RR-5190, INRIA. 2004, pp.16. ⟨inria-00070802⟩
321 Consultations
252 Téléchargements
