Near-Optimal Parameterization of the Intersection of Quadrics: I. The Generic Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2005
We present the first efficient algorithm for computing an exact parametric representation of the intersection of two quadrics in three-dimensional real space given by implicit equations with rational coefficients. The output functions parameterizing the intersection are rational functions whenever it is possible, which is the case when the intersection is not a smooth quartic (for example, a singular quartic, a cubic and a line, or two conics). Furthermore, the parameterization is near-optimal in the sense that the number of square roots appearing in the coefficients of these functions is minimal except in a small number of cases where there may be an extra square root. In addition, the algorithm is practical: a complete, robust and efficient C++ implementation is described in Part IV [12] of this paper. In Part I, we present an algorithm for computing a parameterization of the intersection of two arbitrary quadrics which we prove to be near-optimal in the generic, smooth quartic, case. Parts II and III [4, 5] treat the singular cases. We present in Part II the first classification of pencils of quadrics according to the real type of the intersection and we show how this classification can be used to efficiently determine the type of the real part of the intersection of two arbitrary quadrics. This classification is at the core of the design of our algorithms for computing near-optimal parameterizations of the real part of the intersection in all singular cases. We present these algorithms in Part III and give examples covering all the possible situations in terms of both the real type of intersection and the number and depth of square roots appearing in the coefficients.
RR-5667.pdf (317.54 Ko) Télécharger le fichier
inria-00071229 , version 1 (23-05-2006)
  • HAL Id : inria-00071229 , version 1
Laurent Dupont, Daniel Lazard, Sylvain Lazard, Sylvain Petitjean. Near-Optimal Parameterization of the Intersection of Quadrics: I. The Generic Algorithm. [Research Report] RR-5667, INRIA. 2005. ⟨inria-00071229⟩
253 Consultations
405 Téléchargements
