inria-00071237, version 1
The implicit structure of ridges of a smooth parametric surface
Frederic Cazals
1Jean-Charles Faugère 2Marc Pouget a, 1Fabrice Rouillier
2, 3, 4
N° RR-5608 (2005)
Résumé : Given a smooth surface, a blue (red) ridge is a curve along which the maximum (minimum) principal curvature has an extremum along its curvature line. Ridges are curves of extremal curvature and therefore encode important informations used in segmentation, registration, matching and surface analysis. State of the art methods for ridge extraction either report red and blue ridges simultaneously or separately in which case need a local orientation procedure of principal directions is needed, but no method developed so far topologically certifies the curves reported. On the way to developing certified algorithms independent from local orientation procedures, we make the following fundamental contribution. For any smooth parametric surface, we exhibit the implicit equation $P=0$ of the singular curve encoding all ridges of the surface (blue and red), and show how to recover the colors from factors of $P$. Exploiting $P=0$, we also derive a zero dimensional system coding the so-called turning points, from which elliptic and hyperbolic ridge sections of the two colors can be derived. Both contributions exploit properties of the Weingarten map of the surface and require computer algebra. Algorithms exploiting the structure of $P$ for algebraic surfaces are developed in a companion paper.
- a – INRIA
- 1 : GEOMETRICA (INRIA Sophia Antipolis)
- INRIA
- 2 : SALSA (INRIA Rocquencourt)
- INRIA – CNRS : UMR7606 – Université Paris VI - Pierre et Marie Curie
- 3 : Institut de Recherche Mathématique de Rennes (IRMAR)
- CNRS : UMR6625 – Université de Rennes 1 – École normale supérieure de Cachan - ENS Cachan – INSA Rennes – Université Rennes II
- 4 : Laboratoire d'Informatique de Paris 6 (LIP6)
- CNRS : UMR7606 – Université Paris VI - Pierre et Marie Curie
- Domaine : Informatique/Autre
- Mots-clés : RIDGES – UMBILICS – DIFFERENTIAL GEOMETRY
- Référence interne : RR-5608
- inria-00071237, version 1
- http://hal.inria.fr/inria-00071237
- oai:hal.inria.fr:inria-00071237
- Contributeur : Rapport De Recherche Inria
- Soumis le : Mardi 23 Mai 2006, 14:47:22
- Dernière modification le : Jeudi 30 Juillet 2009, 10:05:25
Documents associés
Exporter
