Relating two Standard Notions of Secrecy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Two styles of definitions are usually considered to express that a security protocol preserves the confidentiality of a data s. Reachability-based secrecy means that s should never be disclosed while equivalence-based secrecy states that two executions of a protocol with distinct instances for s should be indistinguishable to an attacker. Although the second formulation ensures a higher level of security and is closer to cryptographic notions of secrecy, decidability results and automatic tools have mainly focused on the first definition so far. This paper initiates a systematic investigation of situations where syntactic secrecy entails strong secrecy. We show that in the passive case, reachability-based secrecy actually implies equivalence-based secrecy for signatures, symmetric and asymmetric encryption provided that the primitives are probabilistic. For active adversaries in the case of symmetric encryption, we provide sufficient (and rather tight) conditions on the protocol for this implication to hold.
Autre [cs.OH]
RR-5908.pdf (426.43 Ko) Télécharger le fichier
inria-00071357 , version 1 (23-05-2006)
  • HAL Id : inria-00071357 , version 1
Eugen Zalinescu, Véronique Cortier, Michaël Rusinowitch. Relating two Standard Notions of Secrecy. [Research Report] RR-5908, INRIA. 2006, pp.32. ⟨inria-00071357⟩
127 Consultations
131 Téléchargements
