Common words between two random strings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
Philippe Jacquet
We investigate the problem of enumerating the words that are common to two random strings. We show that when the source models are memoriless that the number of common words is sublinear in the length of the sequence, and linear when the source models are exactly the same. We draw the same conclusions for the number of common nodes in the associated respective suffix trees.
Autre [cs.OH]
RR-5899.pdf (296.36 Ko) Télécharger le fichier
inria-00071368 , version 1 (23-05-2006)
  • HAL Id : inria-00071368 , version 1
Philippe Jacquet. Common words between two random strings. [Research Report] RR-5899, INRIA. 2006. ⟨inria-00071368⟩
63 Consultations
174 Téléchargements
