Real Algebraic Numbers: Complexity Analysis and Experimentations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2008
Ioannis Z. Emiris
Bernard Mourrain
Elias P. P. Tsigaridas
We present algorithmic, complexity and implementation results concerning real root isolation of a polynomial of degree $d$, with integer coefficients of bit size $\le\tau$, using Sturm (-Habicht) sequences and the Bernstein subdivision solver. In particular, we unify and simplify the analysis of both methods and we give an asymptotic complexity bound of $\sOB( d^4 \tau^2)$. This matches the best known bounds. Moreover, we generalize this to cover the non-squarefree polynomials and show that within the same complexity we can also compute the multiplicities of the roots. We also consider algorithms for sign evaluation, comparison of real algebraic numbers and simultaneous inequalities (SI) and we improve the known bounds at least by a factor of $d$. Finally, we present our C++ implementation in Synaps and experiments on various data sets.
RR-5897.pdf (696.31 Ko) Télécharger le fichier
inria-00071370 , version 1 (23-05-2006)
  • HAL Id : inria-00071370 , version 1
Ioannis Z. Emiris, Bernard Mourrain, Elias P. P. Tsigaridas. Real Algebraic Numbers: Complexity Analysis and Experimentations. Reliable Implementations of Real Number Algorithms: Theory and Practice, 2008, Dagsthul, Germany. pp.57-82. ⟨inria-00071370⟩
120 Consultations
306 Téléchargements
