Selecting Hidden Markov Chain States Number with Cross-Validated Likelihood - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2006
The problem of estimating the number of hidden states in a hidden Markov chain model is considered. Emphasis is placed on cross-validated likelihood criteria. Using cross-validation to assess the number of hidden states allows to circumvent the well documented technical difficulties of the order identification problem in mixture models. Moreover, in a predictive perspective, it does not require that the sampling distribution belongs to one of the models in competition. However, computing cross-validated likelihood for hidden Markov chains involves difficulties since the data are not independent. Two approaches are proposed to compute cross-validated likelihood for a hidden Markov chain. The first one consists of using a deterministic half-sampling procedure, and the second one consists of an adaptation of the EM algorithm for hidden Markov chains, to take into account randomly missing values induced by cross-validation. Numerical experiments on both simulated and real data sets compare different versions of cross-validated likelihood criterion and penalised likelihood criteria, including BIC and a penalised marginal likelihood criterion. Those numerical experiments hightlight a promising behaviour of the deterministic half-sampling criterion.
RR-5877.pdf (1.22 Mo) Télécharger le fichier
inria-00071392 , version 1 (23-05-2006)
  • HAL Id : inria-00071392 , version 1
Gilles Celeux, Jean-Baptiste Durand. Selecting Hidden Markov Chain States Number with Cross-Validated Likelihood. [Research Report] RR-5877, INRIA. 2006. ⟨inria-00071392⟩
149 Consultations
407 Téléchargements
