A Survey of TCP over Mobile Ad Hoc Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
The Transmission Control Protocol (TCP) was designed to provide reliable end-to-end delivery of data over unreliable networks. In practice, most TCP deployments have been carefully optimized in the context of wired networks. Ignoring the properties of wireless Mobile Ad Hoc Networks (MANETs) can lead to TCP implementations with poor performance. In order to adapt TCP to MANET environment, improvements have been proposed in the literature to help TCP to differentiate between the different types of losses. Indeed, in MANETs losses are not always due to network congestion, as it is mostly the case in wired networks. In this report, we present an overview of this issue and a detailed analysis of the major factors involved. In particular, we show how TCP can be affected by mobility and lower layers protocols. In addition, we review the main proposals which aim at adapting TCP to MANET environment.
Autre [cs.OH]
RR-5182.pdf (293.25 Ko) Télécharger le fichier
inria-00071406 , version 1 (23-05-2006)
  • HAL Id : inria-00071406 , version 1
Ahmad Al Hanbali, Eitan Altman, Philippe Nain. A Survey of TCP over Mobile Ad Hoc Networks. [Research Report] RR-5182, INRIA. 2004. ⟨inria-00071406⟩
143 Consultations
563 Téléchargements
