A new factorization of mechanical words - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Emmanuel Hyon
In this paper, we introduce a morphism on Sturmian words which is tightly related to the coefficients of a particular continued fraction the ceiled continued fraction. This morphism will be applied to factorize periodic Sturmian words called Christoffel words, as well as, to characterize and construct discrete geometric objects called cellular line.
Autre [cs.OH]
RR-5175.pdf (172.16 Ko) Télécharger le fichier
inria-00071413 , version 1 (23-05-2006)
  • HAL Id : inria-00071413 , version 1
Bruno Gaujal, Emmanuel Hyon. A new factorization of mechanical words. [Research Report] RR-5175, INRIA. 2004. ⟨inria-00071413⟩
98 Consultations
173 Téléchargements
