Optimizations of Client's side communications in a Distributed File System within a Myrinet Cluster - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
This paper presents a study of the interaction between high-speed interconnects and a distributed file system client. We use our remote file access protocol and network with the software layer to show how the highly specific programming model of high-speed interconnects may be used in a high performance distributed file system client. We present both a user-level and a kernel-level client implementations with either buffered or non-buffered accesses. These implementations show high performances and may be transparently used by applications. Our improvements focus on pin-down cache techniques and memory registration issues. Our modifications show no impact on its performances while the network usage in the distributed file system client is improved.
RR-5174.pdf (204.83 Ko) Télécharger le fichier
inria-00071414 , version 1 (23-05-2006)
Brice Goglin, Loïc Prylli, Olivier Glück. Optimizations of Client's side communications in a Distributed File System within a Myrinet Cluster. Workshop on High-Speed Local Networks (HSLN), held in conjunction with the 29th IEEE LCN Conference, Nov 2004, Tampa, United States. pp.726-733, ⟨10.1109/LCN.2004.92⟩. ⟨inria-00071414⟩
113 Consultations
251 Téléchargements
