Robust Higher-Order Filtering of Points - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Florent Duguet
Frédo Durand
  • Fonction : Auteur
George Drettakis
  • Fonction : Auteur
  • PersonId : 831153
Processing noisy point data is a tedious task. It often requires smoothing and meshing, followed by mesh processing algorithms. In this work we present a robust filter which operates directly on points using higher order surface approximations, computed iteratively. We extend the bilateral filter by using and filtering surface curvature, and introducing a quality parameter based on our local surface approximation. Using this process input point data is denoised and smoothed, while preserving features. We also extend our filter to allow feature enhancement, by controlling shock formation resulting in sharp edges in regions of high curvature. We show results of our algorithms on several scanned point sets.
Autre [cs.OH]
RR-5165.pdf (1.93 Mo) Télécharger le fichier
inria-00071424 , version 1 (23-05-2006)
  • HAL Id : inria-00071424 , version 1
Florent Duguet, Frédo Durand, George Drettakis. Robust Higher-Order Filtering of Points. RR-5165, INRIA. 2004. ⟨inria-00071424⟩
104 Consultations
175 Téléchargements
