Bernstein's basis and real root isolation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
The Bernstein basis is widely used in Computer Aided Design. We explain how, combined with Descartes's rule, the Bernstein basis, provides as well an efficient method for real root isolation, using De Casteljau's algorithm, and make the link with more classical methods. Most of the content of the paper can be found in previous authors' articles. However, we present a new improved method for isolating real roots.
Autre [cs.OH]
RR-5149.pdf (176.93 Ko) Télécharger le fichier
inria-00071434 , version 1 (23-05-2006)
  • HAL Id : inria-00071434 , version 1
Bernard Mourrain, Fabrice Rouillier, Marie-Françoise Roy. Bernstein's basis and real root isolation. [Research Report] RR-5149, INRIA. 2004. ⟨inria-00071434⟩
237 Consultations
378 Téléchargements
