Dual norms and image decomposition models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2004
Jean-François Aujol
Antonin Chambolle
Following [16], decomposition models into a geometrical component and a textured component have recently been proposed in image processing. In such approaches, negative Sobolev norms have seemed to be useful to modelize oscillating patterns. In this paper, we compare the properties of various norms that are dual of Sobolev or Besov norms. We then propose a decomposition model which splits an image into three components: a first one containing the structure of the image, a second one the texture of the image, and a third one the noise. Our decomposition model relies on the use of three different semi-norms: the total variation for the geometrical componant, a negative Sobolev norm for the texture, and a negative Besov norm for the noise. We illustrate our study with numerical examples.
RR-5130.pdf (1.05 Mo) Télécharger le fichier
inria-00071453 , version 1 (23-05-2006)
  • HAL Id : inria-00071453 , version 1
Jean-François Aujol, Antonin Chambolle. Dual norms and image decomposition models. RR-5130, INRIA. 2004. ⟨inria-00071453⟩
147 Consultations
1050 Téléchargements
