Concurrency in synchronous systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
In this paper we introduce the notion of weak endochrony, which extends to a synchronous setting the classical theory of Mazurkiewicz traces. The notion is useful in the synthesis of correct-by-construction communication protocols for globally asynchronous, locally synchronous (GALS) systems. The independence between various computations can be exploited here to provide communication schemes that do not restrict the concurrency while still guaranteeing correctness. Such communication schemes are then lighter and more flexible than their latency-insensitive or endo/isochronous counterparts.
RR-5110.pdf (487.05 Ko) Télécharger le fichier
inria-00071472 , version 1 (23-05-2006)
  • HAL Id : inria-00071472 , version 1
Dumitru Potop-Butucaru, Benoit Caillaud, Albert Benveniste. Concurrency in synchronous systems. [Research Report] RR-5110, INRIA. 2004. ⟨inria-00071472⟩
145 Consultations
207 Téléchargements
