In-flight structural identification:input/output versus output-only data processing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Laurent Mevel
Albert Benveniste
Michèle Basseville
Bart Peeters
Antonio Vecchio
The problem of in-flight data analysis, for the purpose of structural model identification under both measured and uncontrolled non-stationary excitation, is addressed. Input/output and output-only eigenstructure identification methods are described and compared, within two classes of methods: subspace-based and prediction error. In particular, different types of relevant projections for handling the known (measured) and unknown (uncontrolled) inputs are discussed. The relevance of the methods is emphasized through numerical results obtained on flight test data sets.
RR-5108.pdf (604.16 Ko) Télécharger le fichier
inria-00071474 , version 1 (23-05-2006)
  • HAL Id : inria-00071474 , version 1
Laurent Mevel, Albert Benveniste, Michèle Basseville, Maurice Goursat, Bart Peeters, et al.. In-flight structural identification:input/output versus output-only data processing. [Research Report] RR-5108, INRIA. 2004. ⟨inria-00071474⟩
170 Consultations
255 Téléchargements
