On the Equivalence Between Complementarity Systems, Projected Systems and Unilateral Differential Inclusions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
In this note we prove the equivalence, under appropriate conditions, between several dynamical formalisms: projected dynamical systems, two types of unilateral differential inclusions, and a class of complementarity dynamical systems. Each of these dynamical systems can also be considered as a hybrid dynamical system. This work is of interest since it both generalises some previous results and sheds new light on the relationship between known formalisms.
RR-5107.pdf (144.67 Ko) Télécharger le fichier
inria-00071475 , version 1 (23-05-2006)
  • HAL Id : inria-00071475 , version 1
Vincent Acary, Bernard Brogliato, Aris Daniilidis, Claude Lemaréchal. On the Equivalence Between Complementarity Systems, Projected Systems and Unilateral Differential Inclusions. [Research Report] RR-5107, INRIA. 2004. ⟨inria-00071475⟩
153 Consultations
225 Téléchargements
