Strong Bi-homogeneous Bézout's Theorem and degree bounds for algebraic optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2004
Let $(f_1, \ldots, f_s)$ be a polynomial family in $\Q[X_1, \ldots, X_n]$ (with $s\leq n-1$) of degree bounded by $D$, generating a radical ideal, and defining a smooth algebraic variety $\mathcal{V}\subset\C Consider a {\em generic} projection $\pi:\Cightarrow\Cts restriction to $\mathcal{V}$ and its critical locus which is supposed to be zero-dimensional. We state that the number of critical points of $\pi$ restricted to $\mathcal{V}$ is bounded by $D^s(D-1)^{n-s}{{n}\choose{n-s}}$. This result is obtained in two steps. First the critical points of $\pi$ restricted to $\mathcal{V}$ are characterized as projections of the solutions of the Lagrange system for which a bi-homogeneous structure is exhibited. Secondly we apply a bi-homogeneous Bézout Theorem, for which we give a proof and which bounds the sum of the degrees of the isolated primary components of an ideal generated by a bi-homogeneous family for which we give a proof. This result is improved in the case where $(f_1, \ldots, f_s)$ is a regular sequence. Moreover, we use Lagrange's system to generalize the algorithm due to Safey El Din and Schost for computing at least one point in each connected component of a smooth real algebraic set to the non equidimensional case. Then, evaluating the size of the output of this algorithm gives new upper bounds on the first Betti number of a smooth real algebraic set.
Autre [cs.OH]
RR-5071.pdf (308.96 Ko) Télécharger le fichier
inria-00071512 , version 1 (23-05-2006)
  • HAL Id : inria-00071512 , version 1
Mohab Safey El Din, Philippe Trebuchet. Strong Bi-homogeneous Bézout's Theorem and degree bounds for algebraic optimization. [Research Report] RR-5071, INRIA. 2004. ⟨inria-00071512⟩
216 Consultations
126 Téléchargements
