Flattening of 3D data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2003
The digital library project strives to digitise special collections of libraries; this consists in storing as binary data, photographs of the content of ancient or rare manuscripts. The object is typically not in a flat plane. One collects, along with the photograph of the unflattened object (and the inevitably distorted text), a positional reading of its surface using laserometer. It is then a mathematical problem of how to use the latter information to undo the distortion of the photograph before storing the digitised image. We discuss a variational formulation and implementation of this
RR-5048.pdf (255.16 Ko) Télécharger le fichier
inria-00071535 , version 1 (23-05-2006)
  • HAL Id : inria-00071535 , version 1
Robert Acar, Brent W. Seales. Flattening of 3D data. RR-5048, INRIA. 2003. ⟨inria-00071535⟩
91 Consultations
109 Téléchargements
