Free-form-deformation parameterization for multilevel 3D shape optimization in aerodynamics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
A versatile parameterization technique is developed for 3D shape optimization in aerodynamics. Special attention is paid to construct a hierarchical parameterization by progressive enrichment of the parametric space. After a brief review of possible approaches, the free-form deformation framework is elected for a 3D tensorial Bézier parameterization. The classical degree-elevation algorithm applicable to Bézier curves is still valid for tensor products, and its application yields a hierarchy of embedded parameterizations. A drag-reduction optimization of a 3D wing in transonic regime is carried out by applying the Nelder-Mead simplex algorithm and a genetic algorithm. The new parameterization including degree-elevation is validated by numerical experimentation and its performance assessed.
RR-5019.pdf (5.26 Mo) Télécharger le fichier
inria-00071565 , version 1 (23-05-2006)
  • HAL Id : inria-00071565 , version 1
Michele Andreoli, Janka Ales, Jean-Antoine Desideri. Free-form-deformation parameterization for multilevel 3D shape optimization in aerodynamics. [Research Report] RR-5019, INRIA. 2003. ⟨inria-00071565⟩
469 Consultations
1460 Téléchargements
