Multiscale Expansions for Linear Clamped Elliptic Shells - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2003
We investigate solutions of the two-dimensional Koiter model and of the three-dimensional linear shell model in the case where the shell is clamped and its mean surface is elliptic. For smooth data, these solutions admit multiscale expansions in powers of ε^1/2 where ε denotes the (half-)thickness of the shell. Both expansions contain terms independent of ε and boundary layer terms exponentially decreasing with respect to r/√ε, with r the distance to the boundary of the mean surface. The expansion of the three-dimensional displacement contains supplementary boundary layers, exponentially decreasing with respect to r/ε like for plates. Using these expansions we obtain sharp estimates between the two models in various norms.
Autre [cs.OH]
RR-4956.pdf (501.75 Ko) Télécharger le fichier
inria-00071623 , version 1 (23-05-2006)
  • HAL Id : inria-00071623 , version 1
Erwan Faou. Multiscale Expansions for Linear Clamped Elliptic Shells. [Research Report] RR-4956, INRIA. 2003. ⟨inria-00071623⟩
109 Consultations
135 Téléchargements
